Author Topic: Double Casting?  (Read 2169 times)
Offline Tom Silver
  • Remember, you can't spell GriswOLD without G-O-L-D
Double Casting?
« on: July 29, 2009, 05:11:04 PM »
HI,
I have a #8 waffle iron, and on one of the paddles, part #886A it appears that there has been some sort of "stutter" during the casting process. Almost all of the TM and the words look like there is a "ghost" image that is somewhat offset from the main casting. The second image is pretty faint, and I didn't notice it at all until I had cleaned the paddle. My question is; does this enhance the value of this object, or does it detract from the value? Any info would be appreciated.
"In order to make a man or a boy covet a thing, it is only necessary to make the thing difficult to obtain."  MARK TWAIN, The Adventures of Tom Sawyer
Re: Double Casting?
« Reply #1 on: July 29, 2009, 05:33:14 PM »
Welcome.  You have a ghost mark.   When the patterns were updated,   they filled in the old markings,  and they worn,  the old markings would show though.   And that is why you see a ghost mark.   Added value,   no,  different,  yes.
Will 8-)
« Last Edit: July 29, 2009, 05:34:37 PM by Will_P. »
Re: Double Casting?
« Reply #2 on: July 29, 2009, 07:27:24 PM »
From your description I would agree with Will.  Is there anyway that you could post a picture of your iron??
Offline Tom Silver
Re: Double Casting?
« Reply #3 on: July 29, 2009, 07:45:11 PM »
Here's a photo of that iron. I appreciate the help that you've provided. I'd not seen this condition before and was understandably curious about its origin. Thanks.
« Last Edit: July 29, 2009, 09:32:42 PM by Jerry_Cermack »
Re: Double Casting?
« Reply #4 on: July 29, 2009, 09:35:44 PM »
Nice ghost. I've never seen one on a WI before. Plenty of skillet ghosts, but none like this. Thanks for posting it.
Re: Double Casting?
« Reply #5 on: July 29, 2009, 10:04:06 PM »
That is core shift.   The sand moved when pouring.
Will 8-)
Re: Double Casting?
« Reply #6 on: July 29, 2009, 10:59:32 PM »
That is for sure not a ghost as they would not have made an iron with the logo off to one side that is indeed a sand shift and I for one am a big fan of pieces with sand shifts!
Re: Double Casting?
« Reply #7 on: July 29, 2009, 11:39:58 PM »
I need some help in trying to think through how this might happen.  I think part of my problem is that I really don't know what a waffle iron pattern would look like.  My assumption is that each paddle is like a skillet with one half of the pattern being the outside and the other half the inside.  The mold would then split along the outer edge.  I also don't really know the process that was followed to make the mold.  Would some sand be put in, tamped flat, then the pattern set in and the rest of the sand put in and tamped for both the top and bottom? (that's my impression anyway).
If you look at the picture, every letter and logo line is offset the same amount - a perfect shift.
In my mind that had to have happened during the construction of the mold.  I just can't see how a shift during the pour could have such a perfect, consistent result.  I can understand a core shift in a hollow casting like an engine block but I don't see a core being needed to make waffle irons.
Here's the only way I can dream up to make an iron look like this.  The mold was being prepared.  Some sand put in and tamped.  Then the top pattern was just set in, no extra sand or pressure applied.  For some reason the pattern was then removed and put back in right away, without smoothing out the sand, in a slightly different position.  The result would be the offset of all the lettering and logo leaving the light impression we see now.
That's about the only way my mind can make it work.  I would appreciate any help in seeing another possibility.
This is a neat piece, but as others have said, just an oddity, not a big value enhancer.  I would have thought it would have been culled and remelted in a quality control inspection.
« Last Edit: July 30, 2009, 12:17:07 AM by tomnn2000 »
